O oilman Jan 8, 2008 #3 If you do not know what is in there 10w-40 semi or 5w-40 fully to top up with. Any well known brand will do. Cheers Guy.
B BRUN Car Skoda Fabia vRS Jan 8, 2008 #5 can i ask why ? you have a Clio V6, look after it !.......put the best in
H HOLLA Car PH1 WANTED Jan 8, 2008 #6 I was just taking the advice given. Im not doing a complete change just a top up. Do you think i should put the 5w-40?
O oilman Jan 8, 2008 #7 If what is in there is not known, then 10w-40 semi is fine, no point mixing an expensive oil if what is in there is mineral base. Next oil change find out whats being used so you can top up with that, or better still provide the oil yourself. 5w-40 would be ideal. Cheers Guy.
E edde Jan 8, 2008 #8 HOLLA said: I was just taking the advice given. Im not doing a complete change just a top up. Do you think i should put the 5w-40? Click to expand... I'd use it yep fully synthetic a decinet stuff infact change the cars oil anyway.
