What pads and compounds to use next.
Mr R.
  A special one.
Hi all some help needed please.
I was going over the Clio last weekend with the DA, a white hex logic pad and AF Rejuvenate.
The problem i was having is there was some light scratches that i could see in the roof and bonnet and some swirls which the combination i was using did not seem to shift.
So my question is whats the next "step" What pad and compound should i go up to?
Ive also got my misses car to do which is a sliver Corsa, the paint work needs alot of correction.
Oh forgot to say that i do have a Rupes rotary but i do not have any pads for this.
Cheers in advance
​Scott.
TheEvilGiraffe
South East - Essex
Did Ant correct this recently....?
If so, I'd suggest looking at your regular cleaning regime rather than keep polishing the life out of it ;)
Also .. rejuvinate is a cleanser - you won't lose any scratches with that from what I can work out !
Mr R.
  A special one.
Did Ant correct this recently....? If so, I'd suggest looking at your regular cleaning regime rather than keep polishing the life out of it ;) Also .. rejuvinate is a cleanser - you won't lose any scratches with that from what I can work out !
Yes mate he did and the scratches where there then. He suggest about wet sanding the roof and bonnet but the ones i noticed i was thinking maybe i could get out with a better pad and compound combo.
​Ill need this when doing the misses car anyhow.
TheEvilGiraffe
South East - Essex
If you're happy with the hex-logic ones - get something a little chunkier. The white one is a very low-cut (if anything?) for cleaners/LSP etc.
Get a med/high cut and a polish or buy a few things from 3M's range (on CYC/I4D) as it's all colour coded/idiot proof .. even I managed it :eek:
Mr R.
  A special one.
I don't know enough about it mate tbh, the pads ive got seem ok but it was a recommendation from here when i wanted to polish my brother-in-laws car.
I guess there is a correct pad and compound combo that i need, wether it be for my DA or rotary then im all ears (yes i know they are a little big)...lol
Scrooge
  E55 AMG
It just needs a lot more time spending on the problem areas, a DA certainly won't shift anything any time soon mate.
  Honda & VW
you reckon, have you not seen some of the results that can be achieved with a DA assuming the right pad/polish combo is used?
Mr R.
  A special one.
Glad you've popped up mate, i need to book the car in the have the bonnet wet sanded please.
Mr R.
  A special one.
I could do mate but im going out in the car to that Essex meet tomo night.
The car needs a clean tbh. How long will it take, all day?
