What size bolts/studs for 15mm spacers
Car  Discounted 1*2 parts
Should be fitting my delta mic spacers this week and have been advised against using the standard bolts.
What length/spec of bolt do I need to order?
Is it worth getting a stud kit over bolts?
Tom
Stud kits keep the hub/spacer/disk/wheel all nicely aligned for making it easier to change the wheels so worth doing if you change your wheels a lot (ie if you do trackdays)
Its only for the DCI but thought if there isn't much cost difference between bolts and studs, studs may be easier
Do you know what length I would need and the thread pattern?
M12 * 1.5 if I recall correctly but I can check.
Measure the standard ones and go 15mm longer is the obvious answer, im not sure what the standard bolt length is on the DCI offhand though Im afraid.
