What to do if...
  Valver Lookalike Mk1 Ph3
your back end starts to go?
Just reading the other thread and I know it's wrong to slam brakes on - so what should you do?
  Red Clio 197 F1
Just get off the gas, but watch the tale snapping the other way, so might need a little opposite lock.
Really depends on how far the rear end has gone round :)
  SC 172 FF
aparantly dip the clutch (this helps 2 slow u down wivout skiding) and steer in2 the skid - so if ur bk end swings out 2 the right u steer 2 the right....thats iirc
wen it happend 2 me though i just froze! then i startd jabing the brake pedal and steered in2 the skid at the last minute just in time 2 stop me mounting an irland lol
Steering into it makes sense actually (I just got on all fours and pretended I was a car rofl).
  Illiad MkII V6
A good way to practise loosing your back end and controlling it is to find a large empty car park when it is icy/covered in snow and play around doing a few handbrake turns. You can try using opposite lock, etc so that if you should be unlucky enough to lose your back end in a real situation, you might not panic as much!!
It is an inbuilt reaction to steer into it though (generally speaking). I remember a bloke in Performance Car or something letting his 3 or 4 year old steer while he did the handbrake thing in a carpark and apparently the kid steered into it! lol
  Octavia VRS
first time I lost the back end of a car, I over corrected it and put my dad's pretty new Meggy (at the time) into the nearest wall.
Had good practice in the Clio over the years tho
Ad
  MK2 FRS
Firey said:
Just put your foot down and steer into it.
^^thats what i was aways told in a FWD car.
In RWD car dipping the clutch slightly is meant to help, but surely in a FWD that will make things worse
  RenaultSport clio 172 Cup
Agree with firey, get on the gas a bit of opposite lock and steer out of it.
Then start doing it for fun! (Obviously not on a public road);)
  Lots of Alfas
Rip3z said:
The normal reaction is to slam your brakes on with opposite lock surely?
This is the normal reaction, slamming the brakes on and giving opposite lock when the back end goes makes it swing the other way and losing control (depending on how fast the car is going). I think the best thing to do is gently steer into it and apply throttle (except on rwd cars) to pull the front end into control. It all depends on road,car and the situation though.
Wait wtf, half of you are saying to steer into it, other saying opposite lock - am I missing something?
Oh this is hurting my brain lol.
See when I had my crash I slid to the left, so slammed my brakes on and turned hard right - surely that is opposite lock.
Djw John
Scotland - South
The best way, according to the skid pan insructors at Knockhill is to hit the clutch and steer into it, its more realiable than trying to power out of it. In an understeer skid you dip the clutch and take some lock off, dont add more in. Having done the course I can tell you the instructors were right!
  SC 172 FF
oposite lock is when the bk ends slides out 2 the right so u turn 2 the right.....if u think about it, ur front end will be pointin 2 the left if ur bk end is slidin 2 the right, so if u steer the same way as ur bk end its the oposite 2 wot ur front end will doin!....sum1 else wil lprob b able 2 explain betta but i kno wot i mean lol :)
also dont steer in2 it 2 sharply or u might start a fish tailing motion!
  RenaultSport clio 172 mk2
You need to remember how the car acts under braking/ accelerating etc also what sort of setup the car has LSD etc etc,
For a FWD car to stop it spinning you need to do 1 of 2 things, Either get traction on the back or Correct the steering direction. Ideally both.
By hitting the brakes you take weight off the back and make it easier for it to spin round as you will be reducing any traction that is on the rear wheels also by braking hard you may lock the front wheels up this prevents you from steering stopping you from correcting the cars direction. The back end is moving in a different direction to the front if you stop the front the wheels acts like a pivot for the rest of the car to spin round.
The best way is stop it is to keep the power on (Dont just floor it though you need a some but not all the power) this will a keep the front wheels turning allowing you to steer and correct whilst keeping some weight on the rear wheels and helping it to get traction to the back. Remember power comes from the front and because of that the rear wheels are being dragged (rather than pushed if RWD) and you need to pull them into shape by accelerating. When correcting its easy to over correct and come spinning off in the other direction. Your actions need to be positive but not harsh.
With a RWD car things change, If the back end starts to go you need to come off the power Gradually. Sudden change in power Ie. Dipping the clutch or lifting right of the throttle or hitting the brakes are BAD and you will either continue to spin or more likely snap back in voliently and then it starts to spin in the other direction (Fishtailling). Again by adding more power you will only increase the spin speed and swing round more aggressively. In RWD the wheels are being pushed out of line and you need to stop pushing them in the wrong direction.
If you have a LSD (in either FWD or RWD) then the same things happen but to a lesser degree making controlling it a little easier.
For example I have a RWD Lotus Sunbeam, Very Powerful and very lively and with the LSD very controllable. When the Ass comes out in that, If I squeeze the throttle down (accelerate) it will come further and further out of line until it spins, If I snap off the power then it fishtails If I hold it where it is it will drive sideways and once everything is balance it will straighten itself out, But you dont always have the luxury of time to do this so you need to encourage it by gradually coming off the power and steering into the slide.
  Red Clio 197 F1
^^ wow CrazyK, that is some writing and a nice explanation!
As others have said, the best thing is to go to a nice open play ground and trying various things.
The most stylish is steering in (opposite lock) but on a slippery cold undulating tight road could end in disaster.
Personally, I have got used to quickly releasing the revs but watch for a bit of tank slapping :)
Just take care as our little FWD pocket skuds can take you by surprise.
They are rare and appreciated little cars, but we don't want an U shaped cars please!!
Like this?
Tighten My Nuts
^^^ agree - definitely need throttle as well.
Steer into it, and get on the gas smoothly...but HARD.
If the backs coming round, the car isn't balanced i.e too much weight at the front, not enough at the rear.
Steering the front into it will slow how much the back comes round but you are still out of balance.
Getting hard on the gas helps by driving the front further into the skid and also shifting a bit of weight rearwards to help regain balance and traction.
