Whats the max size wheel on a std mk3 clio?
Car  1.2 TCE Clio Dynamique S
And does anyone know the ET I should look for so that they fit 'properly'. Standard wheels are 16's so I think that 17's with lo-profiles shouldn't be a problem, just wondering about 18's.
Wiltsteve
ive got 17s on mine and its fine...make sure you invest in some new springs or coilies cos theyll make it look 4x4!
Any idea on the ET?
If you've replaced your wheels, can you look at the ones you've taken off.
Wiltsteve
35-45 is fine iirc. My winter wheels are 36 and my summer ones 45. No rubbing or anything.
edit: that's on a mk2 (didn't read the title properly).
yeah mk3 http://www.cliosport.net/forum/showthread.php?t=316871
nope nothing. but listen, i dont have a clue what im talking about here i just ordered my wheels and papped them on!! il go out to the garage and check later on what it says on the back cos they are off getting cleaned atm.
what is it you are looking to do to it?! should mention mine is lowered 30mm and its all fine...
I'm not trying to 'do' anything just it is one of those things that if you don't check you can end up with some really strange ET's and then have to get spacer or have the wheels rub on the inner wings.
Good to know that 17's fit no problem. I've seen one on here with 18's too. But you are right about them needing lowering!
:D
Wiltsteve
fire some new wheels on! you know you want to!
if yours is the turbo with the kit like the one im thinking about then lower it and leave it..or change the wheels depending what colour it is. the kit finishes it off imo
