Wheel bearing
Went out to the Bucks meet last night, and James (iirc) diagnosed the problem as a bad wheel bearing. So at lunchtime I got the car jacked up and rocked the back wheel, there was lots of movement.
Trying to keep up witht the guys last night through the twisties, I thought I was going to die. Steering was wandering all over the place and when I brake it pulls really hard to the right. I'm also slightly concerned that if one has gone, should I be concerned about the others?
Anyone know where I can go to sort this out on the cheap? Someone told me somewhere but I can't remember.
Lace
not braking in a straight line is a different problem.. your other wheel bearings will be ok if its just that one.. does it make a whiring sort of noise ?
pretty sure a dodgy wheel bearing would affect its ability to brake in a straight line.
Its more of a chirp/moan.
if wheel bearings affected it like that the car wouldnt move in a straight line because the bearings are found in the hub and are used as long as the car is moving not just braking.. that problem sound more like tracking to me
thats tracking or wheel allignment as some people call it.. when you get that done make sure the people use lasers and not the old fashioned equipment..
if there is play in the wheel then its most likely a bearing, they are £25 each from k-tec or about £11 from GSF , will need to have them pressed into your rear disk, a garrage will do this for about £20 for you
perfect, thanks babe :)
