Wheel Bearings '92 valver
  On the lookout
Anyone know much about the rear wheel bearings? Do I need to buy discs at the same time, or am I able to put the discs on the new bearings?
£150 from renault, and the bearings are ready pressed into the disc.
Or
£120 from Partco, and you have to get the bearings pressed by someone.
  Valver
So you need new discs and have gd bearings? Or you need new bearings and want to keep the discs? Or you need both? :S
  Ph1 172
If your discs are ok (not warped or anything) you can just buy the bearings, but you need somewhere to press the nackered bearings out and the new ones in. To make it easier you can buy the discs with the bearings already pressed in which is obviously more expensive.
where the feck are you lot getting prices?
nykola is right.
Discs are 55 ish inc vat from renault and include the bearings.
