Wheel Bearings
  RB 182 cup,astra sri
I have a 172 cup with 44k on the clock. its going to be 5 years old in july.
I have started to hear a whining noise coming from the rear which i immediately thought would be the bearings going!
Is it not kinda unusual for these to need replaced after this kind of mileage? am i just unlucky?
how much would i be talking to replace these? parts and labour
cheers
CP
arent the rear discs pretty expensive? no they havent been replaced but they barely work anyway! should this solve the probelm then?
DrR
  VW Golf GTD
£175 for genuine discs with pressed in bearing and pads from yozzasport, get it done.
Mine went at 50kish.
  Lots of Alfas
GSF are selling the genuine Renault discs complete with bearings on ebay for £130 delivered. Its quite simple to fit yourself with a simple socet set, and torque wrench, you will also need a 30mm deepish socket piece. renault also recommend you change the nuts, you will need 2X 7703034258. The discs with bearings are 7701204901. Youll need some decent pads aswel!!
TBH its a waste pressing new bearings into worn discs.
