Wheel offset / size
  Itb'd 182
Picking up a 182 saturday
Had rota grids on my old non sport and my 172 cup and was wondering if the new rota grid drifts 16x8 et10 would fit and not sacrifice the handling
if not would 15x8 et0 grid v's fit anyway better ?
i know you may have to run camber shims , would 1 degree rear shims and 1.5 degrees front camber be enough ?
cheers dan
you will struggle with both those wheels, with the grids you will have 48mm more poke, with the grid v's you will have 58mm more, i run grid v's 7j with et20 and there tight, I had to roll my rear arches and made some camber shims. PM if you need help with this, i may get some 8j wheels soon but you will need stretch and camber a bit of work.
