What are the best products for sealing and waxing alloys? I'm after a deep protection and hopefully a good resistance to brake dust, or at least so that it washes off easily and doesn't get burnt on
Nah something like autoglym extragloss protection is fine. Its a paint sealant thats very durable, and long lasting. I used it my my turinis and they came up fine
Auoglym Super Resin followed by there Extra Gloss protection works as well as anything. Holds up well to the temps. Just takes a while to do due the cure time.
I try and get a couple of coats on once a year then use a easy on and off WHEEL SEALANT when I get the chance inbetween which can be applied in 5 mins of so to all the wheels.
Yeap the cleaners it have in it will prevent mutliple layers - 2 coats of it will just ensure proper coverage rather than allowing you to build up mutliple layers of it like the Poorboys or Swissvax ones will.
Would you not recommend the CG WG? I do have the Autoglym products but wasn't sure they would be upto the job....the main reason I looked for a dedicated wheel sealant.
I stopped using Rimwax and never purchased the Wheel Guard due to the cleaners in them as I like to build up layers of protection.
Standalone the Autoglym Twins will hold up as wheel if not better as any dedicated sealant, which is why I use them and then top with cleaner free one's as they are quicker to use than re- EGPing.
I use the Poorboys Wheel Sealant or Swissvax Autobahn ones on mine.
