Wheel spacers...
Just an assumption about the bolts but it looks like you might have to put them through the back of the hub or something :S
M
mini-valver
I thought that but I dunno, usually just a dowel type stud that screws to the hub, then the wheel bolts onto that.
i bought some 'delta mics' hubcentric ones after hearing good reviews for £40 posted i think, but they were 30mm
might be worth a google
M
mini-valver
30mm?? f**k me, lol!
I'll be on track a fair bit so they need to be solid and safe with ZERO wheel wobble....
  White Sti Hatch
If your gonna do it and spend the cash get the FK 20/25mm kits Bolt to the hub then wheel to the spacers got them on mine and there mint ! none of the *****in about with longer bolts
M
mini-valver
I had problems with Russ and so wouldn't use him again. I've just ordered some Delta Mics (COHBC, I'll chop you up if my wheel comes off) in 15mm, when they come, I need a machine shope to take 3-4mm off, know any good un's Kev?
M
mini-valver
They'll catch my wing though with 20's, already checked, lol.
Iimushroomzii, I want to run as little as possible because I'm not a massive fan of spacers at the best of times, especially when I'll be ragging it on track.....
M
mini-valver
4mm probably wont either ;)
They are prone for wheel wobble the bigger you get and so by keeping it to a minimum, I'm reducing the chance!
