sorry if this thread has already been posted, couldnt see it but most things are, what are all your opinions on wheel spacers? which ones to go for and what width? thanks guys
do the ph1 172 not have that peice os meat that sticks out were the rear bumper connects? i had 20mm all round and was having mt tyres cut by this so i cut it off and filed it down.
as said lay something flat across the wheel and see were it sits in the arch. i use H&R hubcentric bolt on spacers for mine.
I put 50mm wider track on the front. Personally I leave the rear as its better for handling to have a wider front but 1-15mm on the rear should see it looking fatter without scrubbage
do the ph1 172 not have that peice of metal that sticks out were the rear bumper connects? i had 20mm all round and my tyres were getting cut by this so i cut it off and filled it down.
I run hubcentric FK 20mm bolt to hub type spacers, with flanges on the front and left the rear standarad. It handles very well and is a capable car around the bends to say the least.
What are spacers? do they make ya rims stick out? seen it done and looks sick but confused by all the techs like pcd ... offset... etc . Greatful if someone could briefly explain.
