Was wondering whether anybody else had had problems with this, or if I'm being fed a load of BS..
I bought a brand new set of 15x7" Team Dynamics PR1.2 several weeks ago, and fitted them for the first time at Oulton Park on the 4th June. I had an absolutely miserable day, as the wheels came loose on all 4 corners after only a few warm-up laps! I had the wheels off & on in the pits 4 times checking everything, and even tried 3mm spacers just to be sure there was clearance, but nothing seemed to work. Eventually I went with 32mm long wheel bolts (26mm supplied by TD) torqued up to something bloody ridiculous and managed to get a few sessions in the afternoon. Even so, the car was wandering and rumbling despite the bolts still being tight! I had noticed the front spigot rings were a very sloppy fit on the hub spigot and there was 0.5 - 1.0mm of movement, but whether that was down to the wheels coming loose, or whether the wheels coming loose was down to the failure of the rings I couldn't be sure; however, it was my hunch that the rings were at fault.
I had an incredibly frustrating phone call to Demon Tweeks the following day, trying to explain to the girl that I had tried everything and that there was nothing wrong with the car.. I won't go in to detail of that too much! But she did eventually agree to have them shipped to TD for inspection. I called to chase a few days later and was told the plastic spigot rings they had supplied were the wrong ones - too short, apparently - and that the wheels would be shipped back to me with the deeper rings fitted.
I had pleaded with Tweeks to get me a new set of wheels with the bores machined directly to fit, without these pathetic little plastic bits, but they refused and assured me it would be ok. My next track day is coming up at the 'ring in 2 weeks, so understandably I am very reluctant to have plastic anywhere near my wheels!
Has anybody had anything similar? Particularly with TD wheels and plastic spacers? I'm going to machine up some aluminium spigot rings just to be safe, but it would be nice to hear any other accounts of wheels repeatedly coming loose.
i bet the wheel bolt angle is not right for your new wheels
30 day ban.As a side note, what's happened with chip?
Yes I believe that is correct.When you say bolt seats, do you mean the female taper on the wheel bolt holes?
I encountered this last year. The paint was 'melting' and just wasn't providing enough friction. I sanded the paint off with a dremel wire brush attachment and have had no issues since!
Ok mate, was just a shot in the dark.The wheels were torque checked when I left for Oulton Park in the evening and again in the pits the following morning before going out on circuit.
Sorry, one last thing. AFAIK, unless it was an interference fit then surely when you place a wheel on the spigot it would be suspended from that and there would be a gap at the bottom. Therefore the wheel would not be centralised to the hub.while the spigot ensures the wheel is absolutely concentric to the hub
i'll repeat, I have run, on track with no spigots for entire trackdays on full slicks with no issues whatso ever.
I may come across like I am trying to catch you out, I assure you this is not the case. I am trying to learn from you as I believe I have seen your build thread on pistonheads and I am in awe!True, but the clearance is about 1 tenth of f**k all, so isn't going to matter.![]()
Why did you run without spigots?
One man's blind luck is another man's catastrophic failure, so I wouldn't go recommending people to run with spigots that don't fit or none at all! You might have got away with it, but you were very lucky IMO.
Have you checked what clearance you currently have? surely if its about "1/10th of f**k all" then it'd be fine?
Dave.
they break, I lose them, couple of sets of wheels I have I never even got any for for the exact reasons mentioned of them breaking or going walkies, I run stud conversion on one of my cars so no need to centralise the wheel to put bolts in.
to say its luck I would call misguidance, they are not the reason for your wheels coming loose and they do not make a car in anyway dangerous or likely to fail. ime they are purely to centre the wheel to make putting the bolts in easier. the bolts themselves and the frictional clamping force provided at the mating face of wheel to hub by the bolts is what holds your wheel in place and load bears. the spigots do naff all.
I think on this we're going to just go round in circles so agree to disagree etc etc.
either way I hope you sort the issue as its quite an alarming experience
cheers
Ben
Fingers crossed they get them sent sharpish then.It's ok I know you're just asking questions! I haven't checked the new plastic rings yet, but I'm going to shelf them and just use the metal ones I get from Team Dynamics instead. I'll check the clearance before fitting.. with any luck they'll be a push fit in the wheel and a close fit on the spigot, but we'll see.
