When doing CamBelt...
Car  ValverInBits
....what is changed.
As far as i can see:
  • Aux Belt
  • All aux tensioners
  • Water pump (recommended)
  • Cam Belt
  • Cam belt Tensioners and pulleys
Special Tools required for the job
  • Crankshaft TDC pin
  • Tool for locking cams (at the Flywheel end)
is the phase shifter on the inlet cam also changed? If it is, am i right in thinking that an extra tool is required?
when locking the cam, remebr big Ds up, or half moons up some people say
yer lol, we all know it as big Ds up in my garage, kinda catchey so u wont forget:)
Lol, like it. Do you know about any of the other questions asked? really want to know if the phase shifter is changed?
You will destroy them getting them out (these come out to let the cam locking tool in), about £10 for a pair, not worth messing about with them.
no the phase shifter isnt changed with belt changes you can change it if you like at extra cost but if it aint broke dont fix it
if you do wish to change it you need the pulley locking tool aswell
you should slacken off the inlet and exhaust pullies too when you do the cambelt
core plugs - aka cam seals £11 for the pair
as you have to lock them in time with the TDC of the crank, then fit the CAM lock tool
lock the pulleys in place with the pully lock tool, crack the seal and bolts off the pullys, fit the belt and rotate the pulleys through 4 turns with the tensioner (sp) set in place to tension the belt, then bolt the pulleys backup tight.
you have too do so to get the correct timing and belt tension.
You will need the cam puley locking tools as well.
just whipped off the engine mount to have a reccy' down there. It looks impossibly tight! Once the engine mount is off, the top cam cover bolts are nearly all completely inaccessible!
I'll post some picks in a tick to show you what i mean.
we know LOL
you need to get a angle gauge on the end of a wrench to torque the pulleys too the correct angle... nice
BenR has a special tool to do the job,
Jesus. I think I'm just going to whip the engine out. Lol, i say "whip".
It's the cardboard shield and these two bolts and I bet they are not the hardest of the lot either.
What does everyone think about the state of my CamBelt anyway??
It's done 40,500 and it's a nearing 6 years old
The aux belt looks about the same/a bit better
Thanks guys
Just change the lot.
You'll gain access with the aux belt off, the noise insulation off and the engine raised up.
Cover bolts are all accesable with shallow sockets and ratchet spanners, same with the lower plastic cover.
I dare say nobody will comment on the state of a cambelt from a picture lol.
Just did mine this weekend and while some bits are a bit of a mare its not impossible, it helped me having done it on my previous 1.6 and the setup is very similar.
The soundproofing comes out easy enough which give you some more room, and as you have to remove the mount and support the engine with a jack I unbolted all the mounts barring the upper gearbox mount which allowed me to lift the engine up and down depending on which bolt I needed to access.
The hardest part is getting the intermediate timing cover off (the lower black plastic one) and its a fvcking pig! There is only just enough room and it has to come off a specific way too.
I never slackened the cam pulleys off the renault manual doesn't state to do it either and I haven't had any problem.
PM me if you want the manuals which tell you pretty much what you need to do.
But you will need the cam/crank locking tools and the aux belt tensioner tool.
