where can i find ....
Car  172 SPORT PH2
crank shaft sensor on my clio 172 ph2 ? Guides would be helpfull... gonna try clean it see if it fixes a problem that could be from that.
Look from the pasenger side through under the airbox towards the junction of the gearbox and block. But it's fairly difficult to see unless you know what you're looking for.
Haiving trouble with it starting by any chance? Mine turns over and doesn't fire occasionally so try and give this sensor a poke and wiggle to make sure it connected properly.
yea sometimes, it doesnt start first time... starts fine scond time! but i dont wanna be stranded and it wont start at all cause it is faulty
does it run fine? ever cut out? coilpack is always a possibility for bad ignition.
You will find the crank sensor where the gearbox housing meets the engine. Right on top of the gear box housing there is a little sensor that senses the flywheel motion.
