Where can I fit a sub in here.........
  Skoda Fabia vRS
why not fit it on the left hand side facing the wheel, you would have to stick a guard on the sub and make sure its thin enough though
  20VT Clio & 9-5 HOT
Cos its almost in mint condition and if it was under the car it would be wrecked in no time. Also I have no cage under the car to hold it. Previous owner took it off! Dont think it would fit anyway.
Cheers :)
ditch the tyre. get the stuff from halfords. if you get a flat you spray in this foam and it hardens your tire long enough to get home
  Lionel Richie
Ditch the wheel, get a 32inch sub + a 100000Volt battery to power it + a can of get you home foam, thats what i did (apart from the slight exageration on the sub and battery!!)
