Where can I fit a sub in here.........
why not fit it on the left hand side facing the wheel, you would have to stick a guard on the sub and make sure its thin enough though
Cos its almost in mint condition and if it was under the car it would be wrecked in no time. Also I have no cage under the car to hold it. Previous owner took it off! Dont think it would fit anyway.
Cheers :)
ditch the tyre. get the stuff from halfords. if you get a flat you spray in this foam and it hardens your tire long enough to get home
Ditch the wheel, get a 32inch sub + a 100000Volt battery to power it + a can of get you home foam, thats what i did (apart from the slight exageration on the sub and battery!!)
