Where in/around Leeds/Yorkshire to have coilovers and alignment setup?
len_beach
Car  E92 M3,172 track car
I could drive to one of the known specialists but time is a big issue for me so looking for somewhere local.
Any recommendations in or around Leeds?
I used Allcar Tyres in Huddersfield to setup my alignment and camber. They don't set the coilovers up though.
Cheers Guys. Some good recommendations here.
How much were Track Torque Ash?
They charge £80 for the first hour and £50 per hour thereafter but a Clio shouldn't take more than 1 hour, Just give everything a blast of WD40 before you go so that it's easier for them to adjust :) Corner weighting is an additional £50! They will be able to give you advice on what settings to use although you can also get that from this forum although everyone has slightly different idea's :) I used to run 30 min's of toe out (0.5 degree, roughly 1mm 15" wheel) 3.5 degree's camber and standard on the rear. The biggest difference I find is getting the ride height right and that is where you want to get a pro looking at it :)
