Where is the ECU bracket?
Car  Looking for 182
Having done some searching it seems that the annoying buzz/rattle coming from my car at around 3k revs could be caused by a broken ECU bracket. However I have no idea where this is or what it looks like. Any help is appreciated.
I just went and had a look and it was staring me in the face, I'm guessing this is it :p
What's the best way of securing the mofo in place?
I've decided to glue it with Araldite as a temporary solution. This stuff is amazingly strong so hopefully it will keep it in place for a while.
The peg is to hold it in place whilst it's drying. I'm a little worried that the peg may well be glued as well :p
That was the first thing i tried tbh matey, lasted about a week (couple of journys) best of luck to you!
If it just lasts one journey at least it gives me a chance to see if it is the cause of the rattle. The other rattle I have I am fairly certain is caused by the centre section heat shield (I get this one at about 6-6.5k revs).
Good luck mate with the Aradite, it'll last till it gets a bit of vibration or yu hit a bump :(
You need to brace it up with a thin metal strip and use the original bolt/nut to hold it in place.
Just do what Chris has done above.
It'll take half an hour max with no Mechy skills at all.
