Paddy_g46 ClioSport Club Member Oct 25, 2012 #1 Can anyone point me in the direction of this? Iv seen someone mention the scuttle panel in the past?
Jonny1*2 Car Golf GTD Mk7 Oct 25, 2012 #2 passenger footwell, follow the wiring off the UCH to the bulkhead. Via the scuttle is the way I would go
Paddy_g46 ClioSport Club Member Oct 25, 2012 #3 Jonny1*2 said: passenger footwell, follow the wiring off the UCH to the bulkhead. Via the scuttle is the way I would go Click to expand... So if you remove the scuttle panel you can get to it?
Paddy_g46 ClioSport Club Member Oct 25, 2012 #5 Danlp6 said: yes, and its a 10mm bolt holding it togther Click to expand... Do you mean holding the loom together? Any hints on how to remove the scuttle panel? edit: just seen i need to remove the wipers. Last edited: Oct 25, 2012
Jonny1*2 Car Golf GTD Mk7 Oct 25, 2012 #6 I can't remember whether you can see it through the wheel arch. Wipers off is a ball ache unless you've got a pull tool
Paddy_g46 ClioSport Club Member Oct 27, 2012 #7 Right iv got the wipers and scuttle panel off, but i cant see any electrics, are they right in behind the washer bottle?!
