Yep the take deck is mega gay so I could cover it like that and feed the wire down the side. I had a cool install in my golf as I mounted it in a blower hole and removed the upright parts fo them. I was able to feed the wire into the hole and hide it is that makes sense!
I put mine just towards the driver in front of the driver side tweeter on the dash. managed to wire the thing up under the steering column and the wires are all hidden in the rubber door seal on the inside..... just used the tilting bracket supplied. found when its there it isnt in your face but if it does go off it catches your attention straight away!
