Which First
  Clio 197 R27 Albi
Quick Questions...
I Currently Use...
AG Body Shampooo
AG SRP
AG EGP (Only Winter Months)
Poor Boys Natty Blue Wax
I've Been Given A Pre Wax Cleaner Now, (Dodo Juice Lime Prime).
If I Were To Use It; How Oftern? & Where Would It Fit In?
Before Polish Or After?
Either or fella. SRP and Lime Prime do the same thing, but SRP contains more fillers.
Lime Prime is "cleaner" than SRP, meaning if you have got rid of swirls, use it. If you want to fill them, use SRP.
  Clio 197 R27 Albi
Ok Thanks For The Advice.
I Take It Lime Prime Can Be Used As Much As Possible?
I.e Before Waxing or Sealent, After Washing?
  Clio 197 R27 Albi
Infact To Add To The Above ^^^
Surley If I Used Lime Prime Every Time I Washed I Would Be Taking My Layers Of Wax Off Everytime Instead Of Building Them Up?
Precisely. You should use LP when you want to clear all contaminants and build up, i.e. to start again.
I use it every three months to reapply sealent and waxes.
Jim will be along in a bit, he is always too slow ;)
  Audi A4 AVANT 1.9TDi
Whats With The Captical Letter At The Start Of Every Word, Arron?
LimePrime can give some impressive results.. Esp. if applied by DA/Rotary..
Use it before waxing, yes. This sets the base and allows waxes to bond properly. If you're to use it after washing, you will strip previously applied waxes. It's a 'cleaner'.. it cleans the paint..
Might be worth looking at Dodo Juice Need For Speed; this is similar to LimePrime, but, contains a few protectional properties.
*EDIT, you beat me to it. :)
