Which Grams springs? Opinions please.
ex-Chinese Dave
Car  172 Cup
Currently sorting out a few suspension issues and it got me thinking about springs. My car is a 172 Cup with standard dampers and I fitted a set of used Eibach Sportlines a few years ago. They are a bit worn and replaced the springs that came with the car which were non-genuine. I know that new OEM springs are unicorns so I looked at what's available now and Grams seem to have a pretty good rep. Looking at who supplies them I see that KAM Racing have two kinds in stock. One is the blue spring which is a replacement that lowers the car about 35mm (so I think 10mm more all round than my current Eibachs) and the other is an OEM matching set that restores the original ride height (which I like) but is at a much greater cost (£150 vs £319). I think I would prefer the OEM matching set as I like originality but the price is sadly too high. So, what is your take on the blue Grams springs and would you prefer these over another set of the Eibachs?
I had the blue grams on my ph1 (I think with standard shocks). The ride height was nice, not too low and the car felt planted and sharp. I swapped them out for b14s but I recall thinking they were better than the cooksports I had on other my other 172s.
I've had the blue Grams for about 5 years now, they're a massive improvement over whatever shite the previous owner fitted but they're still fairly stiff. Clearance over particularly aggressive speed bumps can be an issue but it's not a huge deal if you slow down enough
Had the Grams on my Petrol Blue, drove well enough on the road and was decent on track but for pure road driving /commuting I preferred the Eibach Sportlines I had on my Arctic Blue.
I would prefer the original look of the car but the Sportlines I have on look ok. And that’s a good point about normal road driving as I don’t go on track. Autodoc are currently doing them at just £144, if these are correct…
I think the Grams springs are not the OEM spec for the 172 cup, the rears might be the same as standard 172/182 but I am pretty certain the fronts are different ( I am sure someone on here will know).
I looked into this a while ago and spoke with Kam Racing who produce the Grams springs and they stated they don't have any originals to work out the specs. I would definitely like some originals but I think the closest are the Eibach Pro lines..
I had Grams before - way too stiff! the front spring snapped, then the rear spring snapped.
I have Eibach Pro lines - black in colour and perfect for daily use, close to the original springs but with the front sitting lower.
i run Grams on my 2.0 16v van - really like them, sits nice, handles well, doesnt feel too stiff
This runs Pro lines:
this runs sportlines:
Side by side i find both sets of eibachs sit about the exact same height at the rear and the sportline sits about 15mm lower at the front (and looks more level)
if i was buying another set of springs for a clio between sportlines or grams i would go with the cheapest out of the 2 as they are both up there in terms of quality
