Which was to undo aux belt tensioner?
Car  Valver
Just to clarify as someone mentioned a printing error in haynes...
Do I undo the centre with a hex type anti clock wise, then when thats loose I undo the tensioner pulley with a 22mm spanner?
Gonna b pretty impossible to try to hold the spanner while getting the hex in at the same time :S
Hex nut is the lock nut if you like, and the inner 20/21/22mm is the tensioner.
I always though it was a 20mm as I remember as most spanner sets go 19mm to 21mm
Would make sense wouldn't it? But not to Renault... had to but a 22mm spanner specially...
Which way do I turn the centre hex thou?
