Which way for Sportlines on teh rear
Car  Dodgy one
as above, I got no manual with my sportlines therefore have no idea which way they were meant to go on the car obv the writings the correct way up but do they go with the writing facing the back of the car or the front or different.
As ive done a few thousand miles on them now ive a slight metallic knock which has just appeared now and then on bumps from the back end and i'm doing process of elimination so get to the bottom of it
Ive only got the springs to look at and take the damper off left to do
tbh mate i don't think it makes a difference. as long as the writings the right way up you should be fine. when i fitted mine all i did was made sure the writing was the correct way up.
hope this helps:)
Standard springs have a correct way ;) Think its the paint facing the back of the car so thought it'd be worth an ask lol
I wouldn;t have thought what way they are facing is the important bit, more getting the ends of the coil springs to sit in the right position in the spring cups. Cups are shaped to sit the end of the spring in.
