White smoke under hard throttle
Car  bg182ff
Ok Guys I need some help my 2002 172 is giving out White smoke under hard throttle but under normal load it's fine it's not using oil or water and when checking the exhaust for s**t coming out on tickover there's nothing I was thinking headgasket but with no oil or water loss that doesn't add up?? Anyone with any ideas?
I know the 182 exhausts collect a lot of water (hence rotting so quickly!). Mine does it frequently, but can't see it being as much of an issue on a 172 exhaust.
I toke it out after work for a hour and did roughly 20-25 miles and still had White clouds left behind me mr White scooby almost dissapered! :)
Head gasket? If it's really bad you have a problem. Checked your oil and expansion tank for signs of water/oil cross contamination? Plenty of white smoke is normal enough this time of year though. Go and get it checked over before you kill it.
The cars been out every day and there's no cross contamination oils a good colour a lil black bt still got a gold tinge to it :/
