why do i have....
Car  RenaultSport clio 172 mk2
one lambda hole on my decat and one on the begining of my zaust?
ive got a late ph1 with 2 lambda sensors, however shouldnt there be just two lambda holes on the decat??
ive got a ktec full cat back and a k tec silenced decat. this is a bit of a problem as i thought my decat had 2 holes for the lambda, and ive now sold the decat, i guess i will need to get the decat drilled and tapped for the other lambda
i have also ordered a ktec sport cat with 2 lambda holes, so now ill have 3 holes, would it be ok if i got one of the holes welded so that it is sealed?
you should only have 2 lambda holes in your decat, not you exhaust after the cat, my car is the same as yours.
yeh thats what u was thinking!!i had a good look on my exhuast system and there is a lambda on the start of the exhuast after the decat
dunno what to do!
i was saying that because i have a late ph1 like ludaprix, i bought a decat from k-tec but upon fitting it my car had two, so sent it back and they sent a new one with two holes.
but he is sayoing he has a lambda hole in his exhaust.... after the cat!?
hey guys ive found that the decat only had the one hole and a extra hole was drilled in the exhaust to take the second lambda
