Do you know what's different on the upper part of the ph2s?
I have the RS lower on my PH1, (was the better one to use to get them "matched") its fine its only the PH1 upper you need
No advantage if its getting matched, infact they always used to say you got a better result from the worst casting as there is more metal to work with.
Only advantage of a RS one is when your comparing to a standard version
Yes. I still does both thoughMatching the lower inlet to the head is where the big mis-match is.
Are ktec just talking about matching plenum to lower inlet?
