Wierd flickering lights...
  Yozza'd Titanium 182
When im driving along, sat at lights, music on, or music off sometimes my ''stop'' light and ''warning'' light flickers on and off very very rapidly.
I don't know why its doing it or how to stop it. Any ideas?
  Clio II 1.4 Priveleg
Check your brake fluid level. Also have a look at your front pads as a low brake fliud level could indicate the pads may need changing.
Hope that helps.
Its really interesting you have just said that.
Ive just (yesterday) changed both my pads and disks, they wer so low it was metal to metal, should i top up my brake fluid??
also what makes u say that?
past experiance
Check the level first before just topping up. The fluid level should be at the maximum marker after changing pads and discs.
Er past experience???
Renault technician and technical expert for the last 25 years!! ;)
ha, not a bad come back, the brake fluid is in a clear (ish) round cylinder at the top of the engine that says min and max on that correct?
