Williams Collant system flush
Car  Clio Williams
How easy is it to flush through the collant system on these engines. Looking to do this this weekend. Is this a simple job or not?
Remove front bumper (which is piece of piss)
Remove lower radiator hose
Remove expansion tank
Drain out coolant out
Replace rad bottom hose temporary and place hose pipe into right hand expansion tank hose untill clear water runs out left pipe
and vice versa
With hose pipe still in left expansion tank pipe, I removed the top radiator hose
Stick it all back together again and bleed your system once its upto temp
