Williams engine in valver.....
Car  Looking for a ph-quick...
This has probably been done to death but anyway....
Looking at a williams engine to drop in the valver. Its the whole engine so will it be a subframe job or can i use the valver suspension and track and swap the drive shafts over. Also is it just the ecu i need? or have i got top swap the whole wiring loom over?
cheers
Amir
You can just swop the engines the clucthes and gearboxes match up. if you use the Williams box the shafts match up as well.
You can have the 1.8 ecu remapped if you want or buy a cheap replacment ECU map.
Ecu, starter motor, loom, ideally gearbox but not essential as they're the same ratio just a taller 5th on the willy but the willy box is stronger
You can keep the 16v manifold and exhaust system and use 16v drive shafts
Well the engine is whole and still in the car wanted to know the mist hassle free way of doing the conversion.
cheers for your advice!
Amir
