Williams hydraulic/cable select gearbox
Car  Clio Williams 3
Hey guys, looking to put my f7r into a mid engine kit. The problem is, without a hydraulic clutch it makes routing a cable a bit awkward, plus is there any with a cable select?
You need to be looking at newer JR5 boxes but I don't know if it will bolt straight on.
Right, fair enough. Im just looking to keep it as is. I know i can go aftermarket clutch slave cylinder, as you can get them in pull or push, its just a matter of getting it fixed in place and engaging everything correctly. Its just the cable select thats bothering me.
