williams sub frame
Car  mk1 clio 1.4sport
Hi all,
not posted on here for a while due to not having my clio on the road due to an incident with a curb and a white van resulting in a bent subframe!
Therefore i need a new engine subframe... my car is a 1997/8 mk1 facelift 1.4 sport maxim. Now what i need to know is if i bought a williams engine subfarme would it fit as i have found one going quite cheap...
Thanks in advance
Matt
you better check with a renault dealer because they have different part numbers,that usually means they differ in some way, it mightfit into the car but will the steering rack fit to the frame and i think the stabiliser mounting from the engine/gearbox is different. I know the wishbones are different.... hav fun fitting it....
William is a stronger subframe double skinned. same size etc though.
The 1.4RT doesn't have the 4th mount so thre no problem there.
cheers guys! fitting it shouldn't be too much of a problem as have engine crane etc and kind of know what i'm doing and have friends that do! do you know if this is a common problem on the mk1 as ive spoken to a few people who have bent their sub frames with fairly light impact! also drivers side headlight glass... fallen straight out? that common too?
