williams wide track
  Clio 16v turbo
boys you know you say wide track a valver to make it handle better? do you mean change the struts, subframe, lower arms and anti-roll bar for the williams ones? coz roumour is the renault 19 lower arms fit and make it wider???
  320d
This it the parts list for conversion of a 1.8 16v to a Williams wide track suspension setup.. Parts price are a alittle old but give you a good idea.
Springs:
You can use williams springs, 172 springs or clio 1.8 16v springs - I won't list OE part numbers for these as they are dependant on a coloured spot on the original items. Aftermarket wise you can fit any lowering springs designed for a williams or clio 1.8 16v or, alternatively, you can fit coilovers (see below). Stock springs are 125lb and from a 172 full fat.
Front Shock Absorbers:
77 00 838 095 - Williams front shock absorber (40.67 each)
You could obviously also fit aftermarket shocks or coilovers - however, these must be designed for a williams. SInce hubs are the same on valver and Williams only the shocks give the different track.
Wishbones:
60 01 025 842 - Williams wishbone - right hand side (48.30)
60 01 025 841 - Williams wishbone - left hand side (48.30)
Renault 19 16v wishbones will also fit.
Anti Roll Bar:
60 01 025 814 - Williams ARB (72.11)
Renault 19 16v ARB will also fit, as will some megane 1 ARB's (IIRC its the non-16v and non-coupe one you'll be after)
Anti Roll Bar Fixing (At Middle):
77 00 785 788 - ARB Bush (5.49)
82 00 078 548 - ARB Clip (2.75)
77 03 035 027 - Nut (0.73)
77 03 002 116 - Screw M8-2 (0.69)
These items are not really necessary as you will be able to use the 1.8 items but IMO it's worth doing as your original bushes could be quite worn dependant on age/milage of your car.
Anti Roll Bar Fixing (At Wishbones):
77 00 784 170 - ARB Bush (5.49)
77 00 784 169 - ARB Clip (3.61)
77 03 034 017 - Nut (0.36)
These items are necessary to mate the ARB to the wishbones - the 1.8 setup mounts differently so you cannot use your existing components here.
Driveshafts:
77 01 367 623 - Williams driveshaft - right hand side (156.19)
77 01 367 627 - Williams driveshaft - left hand side (156.19)
Depending on if you car has ABS you may also need an ABS toothed ring for each shaft. It may be possible to salvage these from your 1.8 setup but if not then the part number is 77 00 867 344 (14.23) - you would need two of these if applicable. It is also possible to substitle the passenger side driveshaft with a R19 16v item.
Also try ringing round comapnys who make driveshafts I got mine from a motor garage for a lot less than Renault and it a new not refurb part just took a few days to get to made up. However be careful they they don't sell you the valver shafts Halfords etc order Williams ones in but they turn out to bee the same part from a Valver and won't fit.
General Notes:
If you get asked for an oval plate number (i.e when ordering driveshafts etc) you can use 'C57M' which is for a Williams. If going for alternative parts (i.e. R19 16V) then you would need the corresponding oval plate.
Also, going for all new parts will cost quite a lot so i'd try and source some of the parts secondhand.
  Looking for a ph-quick...
Picked all mine up second hand, Shocks cost me £20, got a whole subframe from a willy 3 so didnt have to source the parts individually. Got the subframe for nothing as it was my 'payment' if you like for fitting a williams engine into my mates valver.
I did it to mine - a marked difference over the valver set up. (though that was admittedly completely shagged lol)
Turn in and steering is so much sharper - I keep turning in expecting it to understeer a bit and it just grips and goes, meaning I keep having to unwind lock so I don't clip the inside kerb :eek: lol
I've bumped up the kerb on the inside on a roundabout near me before now :eek: lol
I'm occasionally up near stafford actually - I'll have to remember to drop you a line when I'm coming up so you can have a ride or something :)
G_F
  BMW M3 & Williams 3
Its only not worth doing if you cant so the work your self IMO. I also wouldnt like to be spending all that money on new parts when the car is only worth a grand or so, even more so if you don't track the car regularly
^^^ this is a very good point lol
Mine was so shagged that it made sense to just upgrade everything while doing the standard bits.
It does drive so much tighter now, but be aware that it won't in any sense be an economically wise thing to do lol
  Clio 16v turbo
economically? i wouldnt have a valver if i was arsed about eco, ive put 5 gear boxes in this thing!! still love it tho. ive got racin coilovers so doe fanci forkin out like 500 quid 2 replace them so dya reckon putin r19 arms on would help?
Racing coilovers?
19 arms are longer why would you want to try and use just them the driveshafts wonb't work.
  ValverInBits
I've got most of the parts for this now, just sourcing shafts and shocks (may go coilovers - anyone recommend?).
I Remember when i did my wheel bearing I tried to adjust the track rod end (more as an experiment cos it looked a bit tough and rusty).....IT WAS IMPOSSIBLE
I'm gonna need to get my track rod ends out a long way for this setup since i understand 16v and willy have same Hubs, Rack and Rod ends.
Any tips on releasing my track rod ends??
G_F
  BMW M3 & Williams 3
As Sami says blow torch/gas lamp, can get them from B&Q etc under a tenner, get propane gas, make the trackrod red (literally) and turn with some mole grips, turns with ease then.
