willwood squeeling problem
  williams 2 turbo
had these on the willy turbo for a couple of months, and they have always been the same. if you brake sharpley, no problem, but at low speed, or if you gradually come to a stop they squeel like a bast*rd. i have changed the standard pads, to mintex ones, and have bought shares in copper slip, but they keep doing it. Any ideas. the discs are brembo max if that would make a difference.
The brakes on my old Fiat coupe 20vt used to squeal when coming to a stop at low speeds, they're Brembo's though. It was common on that car for them to do it (everyones does it)
No one ever found a cure for it, even if people fitted anti-rattle shims, the noise would come back shortly after.
If your using a good quality pad and fitting them ok with copper etc and it won't go away then your stuck they are going to a bit after all there not a road caliper like normal stuff.
