Willy 1 rough idle (occasionaly)
Car  Clio Williams 1 112
Hello all
i have a clio willy 1 and It hates idling. The car sounds like its going to stall then revs to correct itself. This cycle contunies untill of course you apply some revs and move off. But when i move off It can hesitate under part throttle as well.
any ideas??. No doubt some sort of idle.mixture sensor is to blame???
Also, my oil pressure gague has stpped working, where is the feed fro te engine to make it work?
Akky.
The oil pressure switch is normally at fault, its located under the exhaust manifold near the drivers side I think it's a 19mm or 22mm spanner,
Check the idle control valve these are also common as fook, give it a good clean and try It
