Anyone found a solution to the whistling noise at high speeds?? Ste
Andi-B Meggy Mk4 1.6DCI 160 Oct 18, 2007 #2 Might be one of two things, your wipers or your drivers side mirror. Your drivers side mirror has a hole underneath.. passenger side has the hole but the temp sensor fills it.. cover or fill the hole
nelson182 182 Full Fat Oct 20, 2007 #3 Or it is possibly the top corners of the windscreen on the outside where there are rubber flappy bits. They catch the wind nicely
Christopher ClioSport Club Member Z4M Oct 20, 2007 #4 it's the mirrors, they all do it. try running a bit of black electrical tape long the bottom edge of the mirror, it solved mine!
makavelli VRS Oct 20, 2007 #5 some rs's have had issue with the windscreen seals doing this as well i like it when mine does it as it usually means im giving it some beans :evil:
A Andyman Ph1 Oct 22, 2007 #7 Mines the wipers. Does it on the non spoiler type and with the spoilers on. Quick flic of the wipers when the whistle starts should reveal if thats what your problem is. Never had a problem from the mirrors on mine
FlameR Mk4 .:R32 Oct 22, 2007 #9 I'm going to try covering the holes up tonight If that doesn't work, might think about getting the wind screen re-sealed
