Window rubbers
Car  cup 182
Clios been parked up for a while and its sodden inside
Water on top of dashboard
Water in both side door pockets
Water in passenger footwell and water inside boot
Is leaking seals a common fault on these cars ?
The seals dont appear to be damaged
Or where else may water be getting in.
Wow - that's a lot of water in lots of places!
How have the door pockets ended up with water in? Sounds like someone had some fun with a hose pipe in there!
It sure does, the interior has also started to mould, and car is damp
The boot rubbers and window rubbers must be gubbed somewhere so probs best bet is just replacing them all
The boot rubbers do let water in occasionally so maybe check that.
Likewise I had leak where the rear washer pipe goes through bulkhead. So maybe check there.
Rest... condensation?? A lot of it??
Water on top of dash? that could only be sunroof which it doesn't have or the windscreen surely?
Was it parked flat or was it parked uphill/downhill?
Car was level, but i think the front window and two door rubbers are perished and letting water in
The boot must be letting water in near the lights or maybe top spoiler
