Windows 7 & cad 2006 help
Andy_con
  clio 182
Mock all you want 😉
Ive got my trusty windows 7 laptop running my trusty version of autocad 2006, been using this setup for 10 years plus.
The other week cad started playing up, every time I click open or save it crashes and I get not responding.
Uninstall cad and reinstalled but I cannot resolve the issue. Its been working fine for over 10 years.
This issue has brought my workshop to a stand still, I did everything on cad.
Someone help, please 😭
Andy_con
  clio 182
Yes, chkdsk /f c: then press enter, confirm the scan and reboot the computer.
It did whatever it did and then laptop just started up. So no idea if it found any issues 🤷
Event viewer shows this
Andy_con
  clio 182
Things are going from bad to worse!
Looks like there is two updates stuck, been stuck for Iver a year 😭
I hate computers
Gavin.
its been working for the past 10 years, i dont understand what the issue could be.
Old software, the event viewer log tells you that the software is not compatible with that version of Windows. Could bean update or anything that’s knocked it out.
You could try a system restore to before it was an issue and hope for the best.
Touring_Rob
This should not be connected to the internet.
If you have an old PC working with some old software you need to freeze it in time. Disconnect from the web (period) disable any/all updates. You just run Autocad and your cnc jazz and thats it - this computer should do nothing else.
You need to make sure nothing dumb is happening - hard drive starting to go bad etc. Then you need to roll back any updates this thing has done over the past 5 years and reinstall your CAD app.
You have have a 15 year old who can sort this for you?
Andy_con
  clio 182
Think im going to have to format the hard drive and start again, what ball ache
Andy_con
  clio 182
Spent fooking hours on this issue, I ended up cloning the hard drive so I could really fook around and it didn't matter. But I had no luck.
Had a friend look at it who does IT for a living, he tried loads of stuff and nothing.
A geeky friend from Holland had a look at it today and after 30mins said I think its Dropbox. We uninstalled Dropbox, restarted and bosh cad worked perfectly.
Put the original hard drive in, uninstalled Dropbox and cad is working perfect.
So it wasn't a windows update issue after all 😬😬
