Megane DCi 147bhp/350nwm
You've heard of hidden files and folders but they're easy to find
I like this little simple trick...you've all probably known it for ages or come across it or even think its pointless but it works wonders for those at work!
I'll give you a little step by step to doing it
Right Click>New>Folder
Right Click the new folder and press rename.
Then hold "ALT" and press 2 then 5 then 5 on the num pad.
This will give you an "alternative" space
Now Right Click>Properties> Customize Tab> Change icon..
Scroll along a few and there are 3 blank icons!!! Pick 1!!
And there you go - you'll only really see it if you click and hold your mouse over it which will select it!
hope this helps a bit
