windscreen pillars
  Renault Clio 172 Cup
1 of my windscreen pillars is looking a bit loose at the top, can i just pull it off and see if any of the clips are broken or do i have to push it up and pull so i dont break any clips ( if there is any left.)
cheers.
  172 Cup
If your talking about the A pillars then all you need to do is pull the rubber door seal off around it, then pull the plastic pilllar from the top and you will see a clip push that together and it will pop off then you can see if there is any clips broken.
Thanks ill go and have a look later, any chance do you know if you can replace the clips or do you have a whole new pillar? and if so any idea how much ?
  172 Cup
It will Probably be a new pillar tbh and theres a few people breaking there clios shouldnt think they would be anymore than £10.
