windscreen seal
Car  A3 2.0TFSI QUATTRO
after going to my car after all the rain yesterday i had a soaking wet headlining near inside light and when i pulled the light out it was full of water so im going to go for a new screen 1) it will be rebonded 2) its covered in stone chips as all roads near me have been re surfaced absolutly c**p.
but i will be replaceing the seals
were can i get the front seals from i would like all 3 for main screen ive looked on renault parts direct but cant find them
cheers
daz
The rubber 'seal' on the outside is for cosmetic purposes. The black bonding that holds the screen to the car is what makes it water tight.
ahhhh i thought it helped seal as well because the top corners have lifted and looking a bit worse for wear
If I was you i'd do the same and replace the lot because they do look tatty after a while.
thats what i was thinking while its having a new screen just to help tidy it up
were would be best to try for them or is it a o/e part only
