windscreen washer
Car  mk 2 clio
basically right, my windscreen washer seem to not have enough power to squirt the water out properl. only one of the 2 holes squirts on each side too. every now and then it will squirt properly onto mt windscreen. will this cause it to fail an mot as it is due in 2 weeks. and is there anyways of fixing this problem, i know the pump is working because i can here it when i pull the lever for it to squirt.
Re: Pathetic windscreen washer jets
There is an easy fix to this problem. I fixed mines last week. You need to remove the wiper arms which are Cnut. To save cracking your windscreen like I done get a ball joint separator from halfords £11. Remove the scuttle panel. Remove the wiper mechanism by undoing the three bolts. Remove the washer tank it is held by one bolt you will see it.
Pull the two black barrels from the washer tank and pull off the two hoses. These are your motors for the windscreen and the headlights. At the bottom of these motors you will see a White piece of plastic holding a black piece where the hoses attach. Open this up and remove the rubber cylinder whith a pair of needle nose pliers.
Trim around 5 mm of each side with a very sharp knife and re assemble.
Put every thing back together and watch those jets gush like a fire hose.
There is a guide with pictures on how to remove the mechanism ect.
okay man thanks for that, ill give that a try when the rain decides to stop, if it does. if i dont get the time will it pass an mot like it or should i get it done first?
yeah some places would fail it mate. Its an easy job once you get the wiper arms off.
orted it now, turns out it was the pipe had split where it bend when you open and close the bonnet as well as it was kinking itself eavery time, just takin a bit of pipe off the suzuki sj my neighbour uses for off roading and plugged it straight on. works fine now
