windscreen wiper going to far
Car  Inferno 225
has any one had this problem, when i put my windscreen wipers on the passengers wiper is going to far and hiting the passenger pillow?? is this a easy fix ??/
lecky
Adjust the park position. There is a 13mm nut holding the arm to the linkage. Loosen the nut and move the arm to new position
Yeah pop off the round plastic cover on bottom of arm, remove nut, remove arm and re-position. Can be very tight to get arm off, wiggle it & spray some wd40 beforehand. Ideally use a puller tool.
