Wing Mirror OEM or Aftermarket? Recommendations?
Car  Renault Clio 182 FF
Guys,
I have only just bought my 182 FF in Black Gold, im trying to get her back to top spec.
The nearside wing mirror has had a whack, (while in the posession of the previous owner), and it has cracked both the glass and housing. Do you recommend simply getting an aftermarket replacement or should I go for for an OEM? I assume OEM would be stupidly expensive...
Is there much of a difference? I have a friend who can paint the primed replacement...
Any recommended sellers?
Thanks!
Be cheaper to get one from someone who is breaking a clio on here, you have access to the market place so id look there first.
a complete mirror, base, glass and cap from Renault is/ was under £100 last time i purchased one, Cant imagine it'd be much over £100 now even if its gone up, You won t need to order a glass if you get the base though!
