wiring autoleads cable
Car  clio rxe
Hi, ive just got the pc99-x12 for the use of the remote controller on the steering wheel on an aftermarket sony headunit, in the most basic of temrs, and pics appreciated, how the hell do i fit it? The instructions that come with it are uselss
I'm none too sure really mate as i had all my ICE fitted professionally, but I've just done a search on web and came across this which isn't really a guide but it mentions that you need a model-specific patch lead. Do you have this?
Quote...
When used in conjunction with Autoleads PC99-XXX range of adaptor leads, the PC99-X12 allows the original Renault steering wheel remote functionality to be retained when installing an aftermarket head unit.
Please note that this part connects to the reverse of the original radio remote display, which often requires removal of the dash top panel in order to install. For simpler installation, see also SRNS003.
This interface does not retain dash display functionality. To retain the dash display, part number DRNS003 can be used instead, in conjunction with a Sony CD changer control head unit.
yeah, got all the gubbins, just cant figure out where they all go, and the autoleads instructions are very basic
Any idea how much it would cost me to get the leads put in professionally, with me supplying the leads?
Have you removed the dash?
Plus isn't there a help line to contact Autoleads, ring them for sone advise.
Where are you based.
i'm in ayrshire.
havent removed the dash as tried to take screws out but when i did it was still solid.
Autoleads helpline is something like 60p a min
Remove screws (11 in my 182, iirc) and A pilars covers, then pull dash out from the middle. does need quite a pull to remove it.
