wishbone bolts
hi all,im changing the front wheel bearing and lower arm/wishbone. ive undone every bolt and nut but have hit a problem.the botls that hold the arm to the front subframe dont want to come out.ive persuaded them with some wd40 and a club hammer but still dont wanna know.any ideas on how to release em before i take a grinder to them? help appreciated
Other than wd and physical pursuasion like you've been doing there isn't much more you can do, you can't really use heat due to the rubber bushes in the wishbone.
have you tried turning them while hitting them with that hammer?
else if you going to replace it....if it ain't broken yet you haven't tried hard enough ;) j/k
yh try hitting them while turnning!
also why not replace them anyhow?
dont think they cost that much!
