Wont idle at all.
  Clio 182 cup
The car drive completely fine, hot or cold.
Put my foot down and it takes off with no problems,
BUT
When I come to a stop and press the clutch in the revs drop as normal but it cuts straight out like I've turned the car off :/
Any one had similar problem or heard of any thing like this ?
The car is a ph2 cup.
Cheers dan.
  clio 1.2 2001 STD
i had a 106. i know they are completly diffrent cars but it done the exact same as this. all i had to do was take the idle control valve off. spray it with maintenance spray gave it a clean. cleaned where it fitted popped it back in and it ran sweet as a nut. hope this helps
Arran
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Assuming its a cabled throttle body and not steppper actuated then as above, IACV fault/fouled up.
Mici
