Won't start
Jack!
Right, first time this has happened since I bought the LY. Drove it this morning all fine, went to move it earlier and it's not starting. Immobiliser light is going out, and all lights etc are fine so I'm assuming the battery is fine. When I go to start it, nothing happens, I just get a constant quiet beep, and nothing at all is happening, any ideas? Assuming it's starter related, but can't see how to get to it to check the connections etc.
Help greatly appreciated, don't want to have to deal with breakdown home assist if I can help it.
Nothing from the starter at all no clicks? You may need to give it a knock see if that gets it into life
Ps. Its by the exhaust manifold
As said trying giving the starter a knock or if it bump starts then I bet it's the starter I take it the red flashing light go's out ?
Had a Similar Experience recently Turned out it was the battery. You could try jump starting or charging battery. On Mine all the lights and radio were working perfectly but the starter motor would not turn over. Rac Guy said the starter motor requires much more power to turn over than lights or radio e.t.c
Similar thing happened to mine, turned out the be the lower earth strap.
Way to test it out is the a jump lead and put it on the negative on the battery and the put the other end on the engine block some where. If it starts then its a bad earth.
About an hour after I posted this, I went to start it and it started perfectly, and has been fine again since. But thanks for the advice, I'm sure it'll pop up again soon and then I'll give the recommended solutions a go.
I'd assumed it was starter related, but from what I can see, there's no way to get to the starter from the top of the bay?
Try to clean the Crankshaft sensor under the airfilter box..
Sent from my iPhone using Tapatalk 2
