would a 2.0 cliosport engine fit in my 1.2 16v clio?
Status
Not open for further replies.
Rob
Yes, but the fact is it'd cost a lot more than selling yours and buying a 2.0.
Seeing as the sport's look better in standard form there's no real point.
Heez
  Superleggera'd Bean
You make no sense. Try to imagine the cost of getting said engine, replacing your engine, fit all the other gubbins needed to at least make your car safe, the extra cost of insurance over a standard 2.0l....
Hmmmm I think getting a 2.0l to begin with will be massively cheaper.
lemonnobby
doing it properly you need engine loom box shafts ecu brakes suspension. and as for a cheap one your not looking hard enough
Mcaff
read this thread (all of it) then ask is it worth it.
http://www.cliosport.net/forum/show...ersion-Questions.&highlight=engine+conversion
the only reason you would consider a conversion should be if you can do it yourself. my car is engine converted however i got my friend to do it for me.
real world costs :
donner car £950
labour £500
belt kit £200 ?
then your talking what parts your going to change when your swapping everything over.
i changed all the bushes £200
bought cheep coilovers £200
braided brake hoses £50
then you have all your oils etc £100 +
theres more than that as well i replaced put away another £200 for other stuff
then mine had a problem when everything was fitted, got that fixed tracking done mot all in that cost another £300
then 4 miles into my first journey the power steering pump shat itself witch destroyed a belt/pully and the pump.
so its going to cost me another £4 - 500
ive made some money back on the non sport parts i didnt use maybe around £5 - 600
all in thats around £2600 - 2800
but thats just geting it running, what about the other parts you want to buy for it. i have ended up buying a lot more for it, decat/rarb/exhaust just to name a few things.
so it becomes rather expensive. buy a 172/182 a good one ;)
my thread if you decided to do the stupid thing: http://www.cliosport.net/forum/showthread.php?568782-Project-s**tbox-172-(In-Need-Of-A-Good-Tidy-Up)
The search function is really good on here you should use it, i found what i was looking for in less than 30 seconds.
Status
